1 - 2 of 2 Posts
09 QP
Are the QP's negative or positive grounded vehicles?
Instructions are saying for negative grounded vehicles to connect for most cars, the red to the pos terminal and the black to a metal engine ground
Why can't I just connect the red ctek clamp to the pos terminal and the blk clamp to the negative post rather than a metal engine ground?
Don't want to fry my new car..
Thks
Ctek
I recently upgraded my battery to the smaller, ligher, more powerful, and much faster charging Optima Red Top Battery ($144 at Summit Racing). The battery has a small accessory wire already attached to battery. I cut of the connector off the end of wire and attached one of the wires that came with CTek charger using butt connectors. Now I have a prewired plug on battery that is even fused! I just bought the new Ctek 7002 charger that is more powerful than the Ferrari brand one I bought for my 360. I think the difference is that the Ferrari version is 2 amp, and the 7002 model is 8 amp. The 7002 has 6 automatic charging modes and charges differently depending on type of battery and level of battery. It can even repair lead acid batteries by chargng with a current that alternates amperage up and down for the first part of cycle to break up acid crystals or something that happens to lead acid batteries. I also bough Ctek 7002 from Summit Racing also for about $110.
1 - 2 of 2 Posts
