I was driving yesterday when a beeping sound came on and I noticed it was the F1 tranny light. The car went into neutral and then shut down. I started it again right away and the car drove normal for a about twenty minutes, until it did this gain. I started the car again and drove it home. Could this be the F1 pump or maybe low on fluid or clutch sensor??This car only has 15K on it!
Well it sure sounds like characteristic F1 clutch problems.
When the F1 starts dropping into neutral, it's usually the wear indicator telling the system that the clutch is worn.
You might need a new clutch.
Clutch adjustment may help for a short while but it's doubtful.
Only the SD2 can tell you.
I had the same problem with my 02CC 2-3 years ago.
The dealer adjusted a potentiometer dealing with the shift time of the clutch (don't know any details...) and it never happened again. The clutch was definitely not worn at that time.
Bert
