The pollen filter works especially great when I have the top down....Think about how STUPID the pollen filter thing is.... If it's working, no pollen gets into the cabin. If it's plugged up..... NOTHING gets into the cabin (including pollen).![]()
Thanks for the info. Quick question: do you remove the left kick panel that mounts on the side of the center dash console, or do you just need to remove the panel that lies horizontal, under the glove box area?On the passenger side under the dash, you remove the cover and toward the back left of that area is a rectangular cover set diagonally. You can see with good lighting that there is a place to grab a slide and the slide unlocks the cover. Slide it off, slide down the filter, install new filter (making sure you see the arrows indicating air flow) reverse disassembly. After doing it once, it is a 5-7 minute job for the do-it-yourselfer.
