Need help with figuring out how to fix this issue
Car is my daily driver so it gets used as it should
It seems like the handbrake mechanism failed somewhere causing it to stay stuck on even tho the lever went down normally
Have never had any issues with the handbrake before
I heard a thud 2 times which alarmed me, I thought it was the transmission or clutch acting up. But I was about 4 miles away from home so I gently continued driving.
About 1 mile away from home Something exploded, sounded like the driveshaft broke or something so I pulled over immediately and looked around the car
Noticed that the rear driver LH side wheel was covered in brake dust which is what led me to believe the handbrake got stuck
Handbrake lever now moves freely with no effect
This part broke. What is this part called exactly? Any idea where to get it? How difficult is it to replace?
137651
That is a brake rotor..If you are asking what that is called then I would let a pro handle it honestly...You can hurt yourself and someone else...Jason
I realized that what it is but initially I thought it was the knuckle/hub assembly.
I'm gonna order 2 new brake rotors for the rear but need to figure out why the brake got stuck on and is still stuck on
Your gonna most likely need new parking shoes as well...Jason
It's the rotor hat.
Because they bind to the drum when the car is parked and they are or get wet.
And / or your mechanisms have seized. Won't know until it's taken apart
