Im getting ready to order the parts to do a clutch and I would like to make sure I have everything I will need. I also want to replace any items that make sense to do while it is apart.
Here is what I have so far:
Complete Clutch
Flywheel
Thrust Bearing
F1 Sensor
Bleeder screw
Trans Shaft Bearing
F1 Pump
F1 oil level sensor
F1 Pump relay.
Is there anything else while its apart?
Thanks,
Scott
seems about right, i can't recall if it is the flywheel bolts or the pressure plate bolts that are supposed to be replaced on disassembly... could be both.
throwout bearing assemly + thrust bearing?
trans shaft bearing = pilot bearing?
I'd do the pilot bearing, definitely, since you'll have the flywheel off. There should be an updated part number for it (old 103887, new 235062). Also, make sure the TO bearing has the seals. Sometimes it comes with them, sometimes not! I don't know why. Just be sure they are there.
If by the "trans shaft bearing" you are referring to the clutch housing bearing (which can get noisy - part #174470), then be sure to score the hole and secure it with Loctite 638.
Discussion Starter #6
Yes thanks. I did not list that.
Planning to change all fluids and filters to include FD lifetime air filter
