1 - 3 of 3 Posts
i have an 07 qp automatic with front and rear parking sensors.
when I turn it on, it works fine. after i turn off my car and then later turn it back on, is it suppose to remember the parking sensor setting (on) or do i have to activate it every single time. it seems for me sometimes it does and sometimes it doesn't, but wanted to see what others experience and if this is something I need to take in.
My experience with my QP is that every time I shift to reverse gear, it'll activate the sensor both front & rear. You can turn off the front sensor if it's annoying but it will activate itself again in the reverse gear. Normally, you can activate the sensor anytime as you like but have to switch it off manually. Well, it took me sometime to try and learn, and it works alright.
1 - 3 of 3 Posts
