Hi all, I have a 1989 222E, 2.8 18v. It's not ran for 15 yrs. I have changed lots of parts Inc, coil packs, distributor, leads, relays, plugs and the battery.
It won't crank of the key, but will with + wire to starter direct to battery. I have the fuel pump running of the key and ignition lights now, fuel to cylinders and good compression.
I am at a complete loss now and need help.
Regards all.
Andy from Liverpool GB
It's all up.and running now, it had numerous issues, wrong relay, poor earth to relays and body, ht wired incorrectly and timing was out. New belt and it's going.
allright! now mine to follow, always starts but have to redo electrics, change all fluids, check brakes and suspension...
first the real mecanics, then interior rebuild!
Discussion Starter #5
Mine was a barn find, 15 years off the road, complete rot box, with no electrics, engine running sweet and off the key. Putting engine back together to run with all fluids in, before I strip it again for a mountain of metal work. Mechanically good, might need shelling, complete shame as I terior is good too.
