1 - 15 of 15 Posts
Hello, I am new in this forum and have a doubt.
I think that my maserati has the oil pressure too high 'cause the indicator marks 5bar and in the users gudie says that it has to be to 2.5bar (the needle to the half). What do you think about that?
I have a '05 Maserati Spyder Cambiocorsa.
Thanks to all
*If my english is not perfect is 'cause i'm from Barcelona
I told that thing to the mechanic and he says that there is no problem but i'm not sure 'cause the users guide says that the needle has to be to the half (2.5bar)
If everyone have the same oil pressure I deduce that this is correct pressure
Discussion Starter · #5 · (Edited)
this is a simply draw of the indicator
(\ l //)
the indicator goes from 0 to 5 bars and i think that, like other indicators, the needle has to be to the half. It's logical 'cause the needle has to be able to mark if you are exceeding the normal pressure or if you are under the normal pressure. If the correct position of the needle is on 5bar, it never can marks pressures plus high than 5bar:confused:
2006 Gransport LE
(\ l //)
Under load, all 4200's peg the needle all the way to the right - and stays there until you come off the gas.
Mine too, as soon as the car warms up the needle stays on the right side. 70psi for the US cars.
I just got home from a ride and when stopped waiting for the gate opening I noticed the needle right in the middle. Maybe I was wrong, I probably only looked at it when accelerating and thought it was always on the left side.
Mine seems like it's always pointing at 70psi. I just got my coupe yesterday and was upset that this issue slipped through the PPI. I checked the owners manual and it states that the needle should be in the middle. I made an appointment at the local Maserati dealership this morning to have this looked at. After reading this thread, it looks like it may not actually be a problem and I feel so much better now!
I still need to get it in for a routine oil change though so I'll keep the appoint.
Thanks for the piece of mind.
1 - 15 of 15 Posts
