This is more of an FYI for an inexpensive fix. The WOLO horns went bad on the QP. I just had a buzzing compressor noise. You can order new horns directly from WOLO or you can walk into Advance Auto and purchase them for half the cost ($24.00) badged as FIAAM and the set includes the air horn compressor. Just use a screwdriver to pop off the WOLO black top bracket on the compressor and reinstall on the FIAAM compressor and you are good to go. The horns come off with a simple twist of a screw. The whole replacement, including grille removal took about eight minutes.
Yes. There was an earlier post that discussed the Stebel horns as a replacement. The FIAAMs sound identical to Stebel GP2/GPA2 horns based on the internet sound clip and I could not hear a difference between the new FIAAMs and the original WOLOs. Also, the parts including the air compressor look identical on all three brands. Based on the news, it seems that the majority of peanut butter products are sourced from the contaminated PCA plant in Atlanta; I'm beginning to think that there is one mass producer for these air horns as well. I believe, however, that the horns are salmonella free.
They are definitely salmonella free. It gets blown out!!
Another great option is the 355 horn set Daniel at Ricambi sells.
I have those on my 360 and let me tell you people get out of the way fast!
The OEM 360 horns are bogus!
