Bought an OBDII reader - finally.
About time for me to get active again. Have been sick for over 6 months, but feel alive again and ready to install Jeff’s ECM & DBW. As suggested by Jeff an OBDII reader cold be useful, so I bought one and read code: P1602. What is that for our car (GranSport)? Sorry, am too lazy to search ifor it here, maybe it has already been discussed!
I also read the following 11 read-outs on the OBDII in a vertical listing: MIL off; Monitors 5; INC Catalyst; Evap; Sec Air; 02 Snsr; 02 Htr; 3 Ready; Misfire; Fuel; Comp. Any comments?
Thanks for your help, whomever whish to respond.
I will try write up a full evaluation on the two control units when I have got it finished.
I have been very glad for all the comments by so many excited "new" members hav made. What a wonderful web-site we have!! Kai
Vendor
MIL = Malfunction Indicator Light, Same as CEL = Check Engine Light
So it's good that it's off, that indicates that you do not have a "major" problem that has set the light.
The rest appears to be reporting what's being monitored by the OBD.
I believe that the code you pulled has to do with the fact that the battery was low at some point, set a code and was recharged. It saves this fact in case you clear it and it keeps poping up... that could indicate a problem.
The OBDII port is located near the driver right knee under the dashboard.
-- Jeff
