Hi, and thanks to anyone willing to help me out with these.
Just picked up my 2004 coupe cambiocorsa yesterday (28,000 miles). It had a clean carfax report, but that's all I know. Bought it at a used exotic car dealership in S. Florida then drove it home about 200 miles no problem. I've learned a lot cruising this board, but still have questions. Any answers appreciated!
1. I have a local Maserati dealership. can then "check out" the car, get the old service records, and get me an owner's manual? I see that you can determine clutch wear somehow by getting a % of clutch left, etc. So imagine there is a plug in computer at the dealership that give me all sorts of info, good and bad on this car.
2. The annoying buzz in the driver's door at around 4000rpm - should I try to get this sorted out or is it kind of typical/hopeless.
3. Car still has the factory warranty. Does MNA offer an extended warranty that I can buy at this point? Does ANYONE?
4. performance: definitely needs at least a tune up - when standing stop full throttle accel in either auto/manual the engine more or less cuts out cold at around 5500-6000rpm well short of redline. Then I/it shifts and the engine roars again. Very jerky what with all the engine cutting in/out stuff. Surely that's too soon for any sort of rev limiter to kick in.
5. off the line starts at a crawl are pretty smooth, anything else you can really feel the clutch engage and there is a bit of jerking, like a very inexperience person learning to drive a manual. This is not in sport mode. I learned today it shifts smoother and the clutch lasts longer in sport mode, so i will try it out. Also, you definitely hear the tranny shifting, subtle medium-pitched metallic clunk with every gear change when in auto mode. Having never driven a Maserati before, I don't know if this is normal or not.
I'm sure if I go to the dealer and have them test drive with me in it, they can tell me alot about "this is normal and this is not" regarding the above but thought I would ask here as well.
That's enough for now, I'm sure I think of more after I've driven it more than once. In any case, the dream has finally come true and that beast looks great in my garage.
