Circumstances Require that I sell my modded 2005 Maserati Gransport. Here is your oportunity to own a dream GranSport with all the performance options, bells and whistles without spending all the time and work required to get the job done.
All the work was performed at Formula Dynamics in Las Vegas, NV with no expense spared. Yes this is the car in the pictures and yes, the car is much faster than stock. You'll know that this is a dream Maserati when you turn into that first corner with your foot to the floor and hear that distinctive and wonderful Maserati V8 at Full Throttle while she grips the road. I hate to sell it but... here goes. I'm currently taking reasonable offers and yes, I am reasonable as well. Don't pass this one up because I can guarantee that there is no other like it.
Only - 8000 Miles
Cambio Corsa Paddle Shift 6 Speed
0-60mph in under 4.8 sec
MSRP: $111,002
Upgrades: $12,000
Do the math and make me a fair offer.
This Maserati Gransport is a True Exotic built in the Modena Italy Ferrari Factory with many of the same options and trim. The Gransport model is much more responsive than the Standard Maserati Coupe with More HorsePower, a performance exhaust co-developed by Tubi and improved firware resulting in 35% faster Shifting from the Cambio Corsa Paddle-Shift Transmission. It also has AeroDynamic enhancements, sits 10mm lower and has a 5% Longer Final Gear Ratio for a Higher Top Speed. The Automatic mode to the Transmission makes this car an excellent choice for those of us who want the option of allowing others an easy way to drive the car without the complexity of a manual transmission or the required use of the paddle shifters. The GranSport really is the best of the best and is absolutely suitable as a daily driver. Even though it has loads of power and excellent performance, Maserati / Ferrari built this car to handle the rigors of everyday driving.
This Maserati was originally purchased at an MSRP of $111,002, with the invoice to prove it.
This Gransport has another $12,000 in performance upgrades including: IForged Wheels / Tires, Sport Handling / Lowering Springs, Performance ECU Chip, BMC Air Filter, Race and Street Brake Pads, Performance Exhaust and Polk Audio Speakers.
Note: This car was only taken on the Race Track One Time and I would recommend that the new owner give it a try at least once, this car is really setup for performance and it's the safest way to explore its capabilities.
Car is located in Las Vegas, NV
Phone: (408) 234-8063
EMail: [email protected]
- 440 HP ( With Mods ) 90° V8 with 11:1 Compression
- IForged Daytona 20" Wheels (Anthracite Finish)
- Performance Sport Handling / Lowering Springs
- Performance ECU "Flip Chip"
- Performance Exhaust w/ Polished Tips
- BMC Air Filter
- Performance Race, Street and Stock Brake Pads Included
- All Mods were Professionally Installed / Aligned
- 285/25/-20 Rear / 245/30-20 Front Tires
- Gransport V8 has all the structure of the most advanced racing engines with dry sump lubrication and twin overhead camshafts per cylinder bank with four valves per cylinder hydraulic tappets.
- Top Speed 180+ mph
- Rare GranSport Model - A True Exotic and a large improvement over the Standard Maserati Coupe
- Bi-Xenon Headlights ( Self Leveling )
- Carbon Fiber Package throughout
- Infotainment CD / MP3 Player or Sony MEX-1GP Deck w/ 1GB Memory in FacePlate (+ $300)
- Aftermarket Polk Audio Speakers Installed
- Brembo Braking System with cross-drilled ventilating discs. Front 330 mm / Rear 310 mm, alloy four-pot callipers, Ferodo Pads, Bosch 5.7 four-channel ABS
- SkyHook Suspension: Front and Rear - Double wishbones, continuously variable aluminium gas dampers with adaptive damping and acceleration sensors on each wheel (Skyhook system), co-axial coils and springs.
- Transmission: Paddle Shift Operated - Mechanical six-speed Cambiocorsa transmission with electro-hydraulic operation and electronic management. A Fully Automatic Mode is also available which does not require the use of a Manual Transmission or Paddle Shifters
- Factory Maserati Red Brembo Brake Calipers
- Carbon Fiber Lip Spoiler
- Aluminum Passenger FootRest
- Clean CarFax Report
- 4 Year / 50,000 mi Factory Warranty and Roadside Assistance
- Serviced at Penske / Wynn Ferrari Maserati and SLK Ferrari
- 6K Mi Service was performed
- 8-way Heated Power Seats w/ Memory
- Dual Power Remote Heated Mirrors with Electronic Collapse Feature
- Security System
- 12 City / 20 Highway Miles Per Gallon
- 23.2 Gallon Fuel Tank
- 178" Length x 71.7" Width x 50.7" Height
- Check out the Maserati Web Site for more details
- Check out the Formula Dynamics Web Site for more details on Performance Mods
Only - 8000 Miles
MSRP: $111,002
Upgrades: $12,000
