1 - 20 of 40 Posts
Can anyone tell me how to remove the rear madserati script. I mean is it a case of hot water/patience and dental floss? Or are there screws to worry about? I suppose the front nose badge has two tiny nuts.
Thanks in advance.
Its not two screws actually, I had to replace mine after vandals tore it off.
The script has three big pins attached, and there are 3 rubber stoppers holding it on.
Open trunk, take the linking off the truck (you need to take those black things off... they need to be replaced afterwards... they are the cheapest maserati part though, at 5 -10 cents.)
next, look at the opening, use a flathead or something to pry off rubber stoppers :]
There will be three holes there though...
Yep, I said screws but meant pins...
maserati script removal
Maseratiboy did you use any glue/3M tape on your new emblem-I mean do new badges come with some sort of adhesive backing?
Any thoughts about the front nose badge? I will have a look in a couple of days as am slightly under the weather and busy.
Why am I interested in knowing this? Am I to replace with with gold plated badges? Am I to replace them with pontiac badges? Am I crazy?
All will be revealed soon but in the meantime guys chime in with your thoughts.
PS No prizes for one who guess' right!
2006 Gransport LE
Or maybe in RED?
No. Sorry! Well not many other options then? I promise to surprise you all!
Now I know, your having neon LED's installed incorporated into the badge so it glows at night !
You were in an accident and the trunk lid is going to be replaced with a used one, but the replacement lid does not have a script. The script on your car is not damaged and you do not want to purchase a new one.
Thanks in advance.
your correct in your train of thought i'd clean your teeth with it first tho , it will get dirty after removing the badges, and just the one nut on the bonnet badge.
Regards loz
2006 Gransport LE
I'm reviving this thread as I would really like to know the final answer:)
1 - 20 of 40 Posts
