1 - 9 of 9 Posts
Hello all, it looks like I have this issue and it need to be cleaned or replaced if needed, however I cannot find a code number for this part. For example 2007 onwards shows the part number in the drawings but not the 2005 model. When I’ve Spoken to Euro spares I’m not convinced they are talking about the right part. Can anyone advise. Many thanks Phil
Ok, they call it a check valve, but is actually a variator solenoid. The pic you have is for a wet sump car...You have a dry sump...part#212423....#19 in the pic....Jason
131161
Discussion Starter #8
Hello mate; no oil light, but an error code P0011.. I believe this might be the issue. I want to take it out give it a good clean and test it. I am hoping it will work.
Chances are if you are getting that fault code the camshaft bushings are worn out and it would require major engine disassembly to repair... Jason
1 - 9 of 9 Posts
