Discussion Starter #2 (Edited)
Our MAXPower ECM is one of our more popular upgrades!
This is the newest generation of Plug and Play Performance Modules for your Maserati Ghibli.
Designed to outperform all other modules on the market!
The MADNESS MAXPower ECM has two versions, one with Bluetooth one without Bluetooth.
Unlike flash tuning the MAXPower ECM by MADNESSAutoworks is undetectable once removed in case you have warranty concerns when going to your dealership.
Please note that the Non blue tooth version comes automatically set to Sport Plus and does not give you the ability to change modes.
Get yours from MADNESS today!
Bluetooth version
Maserati Ghibli - Engine Control Module - MAXPower by MADNESS - Bluetooth Control - MADNESS Autoworks - Auto Parts and Accessories
Non Bluetooth version
Maserati Ghibli - Engine Control Module - MAXPower by MADNESS - MADNESS Autoworks - Auto Parts and Accessories
Experiencing transmission lag with your Ghibli? Want a more aggressive shift map for merging or for the track?
Our MADNESS AutoFlash is your best bet!
The MADNESS AutoFlash relies on updating the maps of*the TCU to allow the gearbox to improve shift times and bypass the torque limiter.
The AutoFlash is a great stand alone solution to improve your vehicle's performance, but*also works extremely well in addition to an ECU tune/ Piggy Back Box.
Get yours today from MADNESS
Maserati - Maserati Ghibli S Q4 AutoFlash by MADNESS - MADNESS Autoworks - Auto Parts and Accessories
Discussion Starter #4
Discussion Starter #5
The upgrade we cannot recommend enough is the BMC replacement air filter!
This will replace the restrictive flow of your stock filter with a free breathing, better performing alternative that is the BEST in the market!
BMC filters are made of a multi-layered cotton gauze soaked with low viscosity oil covered with an epoxy coated alloy mesh to ensure protection from petrol fumes and oxidization due to air humidity.
All BMC air filters are pre-oiled, and they can be washed and regenerated by using the appropriate BMC regeneration kit.
Maserati - Maserati Ghibli - Performance Air Filter by BMC - FB789/04 - MADNESS Autoworks - Auto Parts and Accessories
