Few days ago I had the ill-fated idea to replace the broken low beam headlight of my Maserati Levante.
By removing the hood front panel I was able to access and remove the broken light bulb, even with little space around it.
The problems started when I tried to put the new one in. I am not able to properly install it, as I cannot see if it is correctly positioned and cannot get it to stick to the socket.
I have removed the wheel fender liner as I was hoping to get better access, but I still have little visibility and room to properly access the light assembly.
I am going to try to remove the light assembly next, but I do not know how many more things I need to take apart to do that.
Anyone has done it and can provide some instructions?
