I wish I had taken some, but didn't. Basically with the top half of the way down you can access the 2 bars you need to wrap the strap around. You simply wrap the strap around the bars on the inside of the existing strap, making sure the velcro connection is on the underneath. It honestly took no more than 15 minutes.Have you got any photos of how you replaced them? It's still a bit vague for me what needs to be done.
Alex, what im saying is from the pics your sent to me, all of your straps look to be horrible shape and in my opinion they all need replaced and to do that the top needs to be removed. My straps wont help you. Everything has to work together with these tops..I already asked around, the New top would run ~$5K , mine is in a decent shape no holes or cuts, if you happen to have another set of straps I would like to give it a try, but I’d like to know if you accept returns in case things don’t work out?
also I would like to see your instructions, like I mentioned before it appears the first bar is hidden, but I do have access by hand to the third bar , would that be okay to wrap it on the second and third bar?
thanks, Alex
