This is the reason why going over your car in between maintenance services is important. While going over electrical/mechanical components I noticed the air pump tilted on its side. One of the rubbermounts & bolts had some how broken off. Luckily the constant vibration didn't tear the hose it was resting its weight on. As you can see in the image, I removed the entire airbox with the maf sensor to gain access. I simply cut a similar size piece of more durable plastic, used a screw with a pressure washer to secure it. A quick fix & avoided future headaches.
130257
Erik, I always appreciate folks being creative...Your use of zip ties was excellent...I'm sure a lot of people don't know, but techs. take pictures of the shady stuff we see on cars and share it with each other via text or Facebook..Yours didn't make the cut...Sorry...You need to do stuff like this... :p Jason
