1 - 3 of 3 Posts
Anyone here know where is Rohan working. He is maserati mechanic, used to work at Ferrari of Dulles then maserati of Baltimore.
Any idea about the location of F1 fluid.
Thanks.
Mub
The F1 fluid (CS-Speed at £10 a litre in UK) is located at rear by the diff. There is a screw cap with very little room for manouvre. You have to feel it rather than look at it. Clean it thoroughly first, remove and add fluid with a hose and syringe. I used 5ml at a time. DO NOT REVERSE YOUR CAR ON RAMPS!! use jack stands and tire chocks if you dont have electrical ramps!
good luck
I didn't think you had to run the car...
Just merely put it in reverse with the key on so that the pump actuates and then measure the level of the AGIP CHF in the pump... In the service manual I don't recall it saying anything about starting the car...
Also, I found this: http://64.233.167.104/search?q=cach...x+"Selenia+CS-Speed"&hl=en&ct=clnk&cd=4&gl=us
It is a VERY high spec ATF fluid, the std "Selenia CS Speed" fluid can be
difficult to obtain, I now use Redline D4 ATF fluid which is an even
higher spec .....
1 - 3 of 3 Posts
