Good day,
Welcome to the forum - first off, owning an Italian machine will give you an experience unlike any other. I was waiting for the Porsche comment (nothing wrong with a Porsche) other than it’s a Porsche and you can’t even really compare the two - honestly.
Be prepared for all the quirkiness - you will have warning lights come on for no reason (which can be remedied by turning the battery off/on)….these cars dislike cold weather - but once warmed up, they move ingesting all that cold air from outside (like any other car)….Drive the darn thing - drive it every day…don’t let it sit. Not only let the engine warm up - get the transmission warm to…then drive the hell out of it. Always shift at 4k rpm and in Sport mode to preserve the clutch. Try and look for a car with a leather headliner - or “all leather interior” stay away from that space age looking fabric. Find a good Italian tech to work on your car - it buy the parts if you can from Ferrari/Maserati. Although mine is not installed yet, but the Formula Dynamics Drive by wire to save clutch life and increase performance. Change out exhaust, get either the performance cats or cst deletes as the second set of cats are due to fail and will cause massive engine failire
also, there is a “squashed” exhaust section under the car…which robs the car of power….if you get the sport cats or cat deletes…that section is opened up and freer flowing which increases performance and sound. I am partially biased - get the Gran Sport model if you like the aero aggressive kit, x-pipe and larger wheels. As I mentioned earlier - this is nothing like a “yawn” Porsche - so quality issues with the sticky seat backs and sticky buttons can be remedied by certain members on this forum….heater core can be replace by an Aluminum Saab version….and may need to be tweaked by a few millimeters or…you can bypass the heater core and not use your heat (cabin gets warm enough from the engine. Oil changes - change your oil every 3-5k miles….do it and don’t neglect it…Italian engines have nothing in common with German engines. Air filter - because of the air filter placement (lower left inlet located in the air dam) be careful in driving through puddles in order to avoid hydro lock. Be sure to change out the fuel pump fuse as those are known to fail causing the “over running” of the fuel pump which will lead to it burning out.
Make sure the steering rack boots aren’t torn…not a biggie as mine have been torn for 8 years now (I have the replacement boots) just haven’t put them on yet. The dealer will say you have to buy a new rack but that’s not true. The oil pressure gauge may act “wonky” but I believe it’s just the “sender” going bad and it’s replaceable.
Be prepared to have every kid known to man try and race you from a Prius to a cankle looking Lamborghini (sorry if I offended anyone - take a mental health day or go to your safe room).
These cars are super reliable - do a PPI and buy the best you can afford - drive it every day - don’t let it sit.
You might also need to change out your MaF but cleaning it won’t help - you would need to replace it. Be prepared to spend 5-8k for a new clutch…once you get the Formula Dynamics drive by wire and you understand how to drive it, you can master pro long clutch life. Always feel the clutch engage then hammer it.
Also, look for a car where the center airbag doesn’t have a “bubble” look to it…a lot of these cars tend to have that….mine does not…fortunately…just another quirk for being related to a Ferrari.
I also forgot that you should change out the thermostat and make sure the fan relay has been replaced and is in great working condition…temperatures can creep up fast in warm climates…but thanks to the two powerful fans up front and enormous opening of a grill….if properly maintained…will never over heat.
If well maintained, and you have pockets to run the car it can be more reliable then the 65 Porsches/Corvettes/BMWs/Audis you see at Starbuck’s Buy it, use it…and embrace that this is one of the last, normally aspirated, high revving V8s around…you won’t regret it.
very respectfully,
Stephen
