Dan, let's face the reality, I would look for a new Granturismo, I think by the time you are done with it it will be broken beyond repair.I still find it incredible that neither one of the covers will budge. Inexplicable . ( lol, no the PO didn’t glue anything , I talked to him yesterday ..he’s a very good friend of mine ). My hesitation to sticking a knife blade in there to pry them away is not about scratching the paint next to the seals ( I can protect that with some cardboard ) as much as it is damaging the seals or cracking that plastic cover ..and then I have to order new ones and wait for them ..not that we’re about to see any rain around here where moisture can get into the lights / contacts and cause even more problems.. Eh, I’ll wait for the new lights to arrive and then use a hammer an chisel 🤪. This has to take the spot for the most bizarre trouble with what has to be the simplest thing to do on this car ..two friggin’ screws are the only thing holding that thing in place ! 🙄😠
Add some of these to your collection, perfect for jobs like this.I still find it incredible that neither one of the covers will budge. Inexplicable . ( lol, no the PO didn’t glue anything , I talked to him yesterday ..he’s a very good friend of mine ). My hesitation to sticking a knife blade in there to pry them away is not about scratching the paint next to the seals ( I can protect that with some cardboard ) as much as it is damaging the seals or cracking that plastic cover ..and then I have to order new ones and wait for them ..not that we’re about to see any rain around here where moisture can get into the lights / contacts and cause even more problems.. Eh, I’ll wait for the new lights to arrive and then use a hammer an chisel 🤪. This has to take the spot for the most bizarre trouble with what has to be the simplest thing to do on this car ..two friggin’ screws are the only thing holding that thing in place ! 🙄😠
Oh … License plate light warning and bulb out can be can easily be broken wiring in the trunk driver side inside the flex housing strapped at the trunk hinge … If the broken wire(s) short to metal it will do a lot of damage to components like NCM .. run do not walk to have that checked out !!!Checked ALL lights this morning and at all settings ; parking lights, turn signal lights, auto setting, headlights at low and high beams, the beads lights in the headlight assembly, brake lights, reverse lights etc. All working ; burned out or dim bulbs anywhere . However, the license plate lights are all out ( at every setting ). So it seems that’s what triggered the lights alert 🤔. And in typical Maserati electronics fashion that alert is no longer on ..😐. WTH ?
Yeah, they used to be way better than that....Ok, now I’m not a happy camper : ordered the lights ( from Hoen ) on August 18. I still have not received them, and although I did get a confirmation with an order number ( from 2checkout, the payment source they use ) there was no follow re the shipping .. no tracking number or even a mention it’s being sent . So I emailed them an inquiry, to which there hasn’t been a response for five days . Today I called the number they list for customer support ( called a few times. ). It gets a fast busy signal right away , indicative of a non working or discontinued number . Not that I care about $ 27 but it’s the principle of the matter , something seems off here ..
That would be awesome, very kind of you !! 😊Yeah, they used to be way better than that....If you don't get them soon, I'll send you a few, Dan.
Cool Beans.That would be awesome, very kind of you !! 😊Let me see what I can do in the next couple of days and if still no response from them I’ll send you a DM .
So…in which way does it get worse, which could make it easier to better identify where along all those circuits the problem is ? You mean something other than the license plate lights can be impacted by this eventually ? ( So far, every single one of these tail lights works perfectly, checked all those out a few times )The good news is stuff like this generally gets worse and is easier to fix then...J
