the one that is yellow and looks like the sun with an exclamation mark on itbut which one?
Thanks, I was thinking of waiting until dusk to do that , as well as checking all other lights including the brake and reverse lights ( well, my wife would have to do the checking of those …and I have to resist the urge to “test“ the reverse when she’s behind the car…Juuust kidding !! 😜 ) but got sidetracked and forgot all about it . Will check it out tomorrow morning though.You don't need a scanner for that..Walk around the car with the parking lights on for starters..Look for a bulb totally out or one that looks dim...Most likely a parking light bulb in the front headlight assembly...Jason
That's what friends are for...You don't need a scanner for that..Walk around the car with the parking lights on for starters..Look for a bulb totally out or one that looks dim...Most likely a parking light bulb in the front headlight assembly...Jason
Great, thank you sir ! That saves me a bunch of searching ..
You're most welcome. Last time I placed an order for a pair of bulbs, they sent about 10 extra bulbs.Great, thank you sir ! That saves me a bunch of searching ..
And when I fired it up to drive off to work , the alert light came on again, but with a difference ..for a brief moment ( no more than two seconds ) at the top of the screen it read : “ check plate lights “ , and then it vanished just as quickly as it appeared, and only the alert icon stayed on. I call that the Brigadoon syndrome ( those of you old enough will get the reference )
Ordering them now ..
Could be a lil oxidation/corrosion between the bulbs and the contact/electrical surfaces. Usually just removing the bulb to break contact and re-installing is sufficient. Apply a lil dielectric grease to the bulb/contact surfaces if you want to prevent a future occurrence.WTF ! ( and by that I don't mean Wow That's Fantastic 😛)
Started the car this morning, no alert icon on the screen, drove 15 minutes to work, no alert icon appearing , parked it , shut off the engine, still nothing.. turned on the key just to the all systems on , went to look at the plate lights and they were ON ! Switched the lights dial to the various modes, just like I did the other day when the plate had no lights, and it all works . Fired up the engine, did the whole routine all over, and the lights are on. Again, WTF ?!
Lucky the lights I ordered were only $ 20 ( ok, $ 27 with shipping ..) so I'll keep them until the next time when they REALLY burn out, and not just a bizarre Maserati electronic gremlin like it seems to have been this time..
Thanks, will do that this weekend. In most cases I use CRC electronic cleaner spray for those things so we’ll see if that is enough , and if not, dielectric grease it shall be 😉👍Could be a lil oxidation/corrosion between the bulbs and the contact/electrical surfaces. Usually just removing the bulb to break contact and re-installing is sufficient. Apply a lil dielectric grease to the bulb/contact surfaces if you want to prevent a future occurrence.
This would be my guess as wellCould be a lil oxidation/corrosion between the bulbs and the contact/electrical surfaces. Usually just removing the bulb to break contact and re-installing is sufficient. Apply a lil dielectric grease to the bulb/contact surfaces if you want to prevent a future occurrence.
For the plate lights? They slide and come out....
Probably just really stuck on there because it hasn't been removed in a while. Gentle prying should help it pop off.9
Yes those lights , but I’m not talking about the bulbs..it’s the plastic cover that should practically fall in your hands when you remove the two screws which hold it in place . I even watched a video this morning on that , and the moment the guy unscrewed those , the cover came right off , changing the light bulb ( I hear a joke coming here , at my expense..) is a piece of cake . I just don’t understand why those covers are so solidly frozen in place that they won’t budge . I tried to wiggle them , but it seems short of getting a knife blade in there to pry them off they’re not moving at all. I’m going to have another cup of strong coffee this morning and get back at it ..
Yeah, you're right. I was confused and thinking they were they slide and pull type9
