1 - 15 of 15 Posts
Due to take delivery of a QP later this week. The car is mint bar the keys which have scratches/chips on the blue plastic body of the key(looks a bit ugly). Is it possible to just buy the blue plastic outer part of the key and swap it over?
thanks
Simon
I think that after a few months chips are designed to fall off!
I think that everyone probably has scratches and chips.
Can do some minor polishing job yourself before you replace the shell, use the finest grade sand paper to remove the scratches and then polish the whole surface with tooth paste. It's kind of an easy job, inexpensive, no harm to try if your insist to replace the shell.
Maguires Plastic Polish
works the best... And it's made to clean up minor scratches... Otherwise it's time to buy a new key...
when scouring the net a while back I found a place that made carbon replacement bodys for the keys - they weren't cheap, if they were, I'd have bought a couple to stop it looking like a fiat key! (if there's a group buy.....)
On another note, on the of microswitches inside the key fell off a couple of months ago - had to rip the key apart & bodge it to get home from work. I'd get a replacement unit if it wasn't going to cost an arm & a leg! I'll settle for someone soldering it methinks.
I think it was this site: http://www.ferraricarbon.com/ - they don't list the keys, but they do for the 360, I swear I've seen one somewher - I'll keep looking..
But.. if anyone know's any CF people, it can't be that hard to make a shell for a key now can it?
On another note, I like the longer trofeo style cc triggers would love to see some in the flesh, but they aint cheap.
Ive had the same problem with my QP key. I actually got a can of blue plasic spray paint, and a can of clear laquer. It worked out ok, not perfect, but covering the buttons and other non blue bits was a pain. I was told to try going to a paint shop and have them do it, not a bad idea. i was also told by my ferrari maserati service manager that all the keys are crap and ordering a new one would be a waste too.
you could try to just cover it with a carbon fiber film from stickercity.com. Would be cheap & if it doesn't come out to your liking, you could just peel it off....
Key Replacement
Guys, You cannot just "change" the key housing. The alarm transponder microchip is epoxied into the key housing. The microchip is sealed in a tiny glass vial that will absolutely break when it is attempted to be removed.UNFORTUNATLY the only remedy is a complete key replacement.
The key has three identifying codes 1- the actual key code (to cut the key at the factory) 2- the before mentioned Transponder code 3- the Alarm interface code. The selling dealer either has or can get this info for ordering purposes. Any dealer can get this info for a small fee.
You will need a copy of your license and title to order a new key.
Once the new key arrives, it is IMPERATIVE that ALL keys are dropped to the dealer. The new key needs to be programmed to the car and ALL keys have to be present for subsequent reprogramming or they will NO longer operate. I hope this clears the key issue up.
1 - 15 of 15 Posts
