Hey all. Car has been sitting for two years. I revived it but I'm chasing down errors. I can clear codes and everything seems to work fine for about 5 minutes. Then I get a bunch of warning lights for MSP, EPB, ASR, etc. After that I get suspension failure and power steering failure warnings and the speedometer goes to 0.
I suspect this is why I'm getting errors on all these systems. They all require vehicle speed to function. It is the ABS computer that drops first and then everything else follows. My issue is that if I monitor the NFR data stream I can see all four speed sensors report properly until I eventually get the error on the dash and then they all shoot up to 86mph and freeze there. I don't see a single wheel speed sensor not reporting or reporting vastly different than the others. The 86mph reading might also just be a signal error from whatever the actual problem is.
Recent work performed on the car:
Skyhook module (was reporting inability to to communicate with can bus)
Alternator (completely died)
Battery
Oil change
Voltage is good at 13.6. As far as I can tell, all my grounds are good and connections at the battery are solid. I'm pulling my hair out here. I don't want to replace the ABS computer and just throw parts at the car. I'm acutely aware (thanks to this forum) to ensure that I have good power and indeed I do.
The codes I'm getting after a fresh reset followed by a 5 minute drive are:
NCM Engine Node
Alternator
Battery
Oil change
Battery
Oil change
NCM Engine Node
- P0500 - Vehicle Speed Signal (Incorrect Working)
- U1213 - Invalid signal from ESP CAN Line
- C1622 - Incorrect Processor Request (Master-Slave Incoherence)
- C1250 - Temporary Interference
- U1713 - Parking Brake CAN Message Error
- P0501 - VELOCITa Ruote Posteriori Non Plausible <--- Think it just means that the speed sensor data isn't plausible
- U1706 - No Communication with NFR
Alternator
Battery
Oil change
