Is there an answer for this, by that I mean one which has been scientifically validated? I ask, because in searching this forum and others, there doesn't seem to be a consensus. I know that octane decreases pre-ignition and detonation which I presume is an issue in high compression hot running engines like ours. But if one uses a higher octane fuel (using the same method of reporting, e.g. 91 vs 94 R+M /2 method common in Canada for example) does one
a) get better fuel mileage?
b) improved performance?
c) improved longevity of engine?
The North American manual I believe says to use a minimum 91, but is is worth paying more for 93 or 94 which is reasonably available across NA?
