I want to thank the board for the help getting this to work so easily.
I was able to get the Dennison unit from the UK 129 pounds with shipping to the states. www.ghc.co.uk it arrived 2 days after it was ordered. The part numbers are below.
Product/Description
ICE LINK PLUS CAR SIDE (BLAUPUNKT/ALFA/FIAT/MASERATI)
Code: 39823 Qty Sent: 1 Qty Owed: 0
ICE LINK IPOD CONNECTION (MINI IPOD 1G ACTIVE CRADLE)
Code: 38167 Qty Sent: 1 Qty Owed: 0
The install was straight forward as decribed else where. I however not only took out the 2 small screws in the console and the 2 under the rubber mat I removed the 4 large phillips screws at the rear of the console afer removing the hinged cover. I also removed the rear vents that are pressed in in order to gain access to the connector on the amp. I do not know how you guys fit the connector on without removing all these items. With the rear screws out and vent removed you can see the connector better and gain a few valuable mm of room for your hands.
I plugged it in mounted the craddle stelthly in the console box and it all worked first try.
Does anyone have it so you can see the song titles on the screen. All I see is the song number. The song name does appear on the ipod still.
In my other car s2000 with a Alpine the song name comes up on the radio but the ipod is blank other than the Alpine logo.
I am very happy to have my tunes in the Coupe!!!
Product/Description
