Changing the springs will not lower your ride height.
If you change the springs to stiffer alternatives you might throw the Skyhook software off balance.
I'm guessing that the software has been programmed with factory fitted spring rates and therefore works within specific parameters to achieve optimum handling. In which case, if you did change the springs the dampers would not behave properly and you might end up with problems. Alternatively the software might be "self learning" and automatically adjust to the new spring rates.
I would contact Maserati in Italy and talk to the technical department to see what can be done.
Regards,
J.P
