1 - 12 of 12 Posts
I just put lowering struts on car and installed strut deletes and bigger tires in rear and drove it no lights on, put it on the rack to do an alignment and of course camber is way out ,I tried to adjust as far as I could. While getting it off the rack I bottomed out . then drove it about 1 minutes later abs light steering epb light, suspension light came on check engine light speedometer stopped working, figured I have a bad speed sensor.(or maybe the steering angle sensor needs to be rest but tow was not that far off) I was able to pull codes in engine module I had P1060 B1014 (I think this code is right abs sensor, not sure front or rear) I pulled codes from every module that it will let me.(new scan tool Foxwell only let me read codes no data and still cant reset oil light it said it would do that, that's another story) I will list them out if anyone has place that I can get a explanation of what they are, p1060 or its p1 060, po500 Velacita ruote posterior non valido, u1706 activity ,u1601 can line ,b1014 rh position,c1250 temp interference, u1713 p-brake can message, u1715 side accerlation sensor,u1313 ESP can line, I do under stand some of these are can buss communication codes, but I know that one code will trigger others to come on, I fell its abs sensor or steering angle sensor needs to replaced or relearned , car sits for about 15 minutes all light go off but the check engine light( cause I didn't clear)after driving for less than 1 mile abs lights comes on first then all others follow. If anyone can assist me on this and maybe a scan tool that can reset my oil light.
Hey I’m having the same issue after getting tire changed at the dealer, rear right. I had a 30 series on the left but they wanted to put the original 35 series on the right. This was an emergency case as my tire blew on the highway and luckily there was a dealer close by that i knew would have my tire. Waited for ever, got back on the road, and 5 minutes later my dash started lighting up like a Christmas tree. Did you figure out your issues? I have a Fox well 80pro, but similar to you, i think most of the codes are 2ndary to the real issue.
The tires on the car need to be the correct size...It changes the circumstance and that changes the wheel speed sensor output that sets off everything...Hence, all the dash lights...Jason
That’s what I figured. I’ve since had the other tire changed over to match. The lights persist. I’ve been reading about a reset but have no idea how to do that. I’ve had the battery unplugged a few nights then back on. Takes s few minutes of driving but the warning lights come back. I’ve also reset the errors with a fix pro, but again, they come back. Any ideas?
So since I have the correct tires now. Is there something i need to do to reset the speed sensor? Still getting all the lights.
Dash shows; EBD, ABS, MSP, ASR, Power Steering, Check suspension.
Code reader shows; U1213 ESP Can, C1250 temp interference, C1313 missing park can, P0500 speed signal incorrect, B1005 no can message, U0100 Malfunction ECU silverbox
what faults is it producing?
Maybe you already checked this but make sure your battery is good and your voltage is not low. Low voltage will set off all kinds of warnings in these cars. Even just from leaving the ignition and headlights on for a relatively short time while you are trouble shooting and pulling codes.
By the way the DIY section is supposed to be for "how to" write ups not troubleshooting. I know you bumped a thread with the same issue but you get more help usually if you post in the sub forum for your car.
Sorry about that. Yes, battery is new. Voltage at the battery is 12.8 off and 13.4 running.
1 - 12 of 12 Posts
