Info on clutch wear....
16474 Views 30 Replies 20 Participants Last post by  [email protected] Enzo`s Atlanta
Hi Guys,
Just got of the phone with the Maserati service manager. Here is the bottom line with the clutch questions (that many of us have had)
1) New clutch with flywheel...$4800.
2) The clutches will operate fine, no issues until the car clutch has used up 70-80% of its life. In other words, if you have the clutch wear tested and they tell you your clutch is "at 50%" that means you have another 30-40% before...you get the $4800 bill.
3) Driving in AUTO ( as in common knowledge) is a bad idea.
This was new to me...hopefully, this helps you.
1 - 20 of 31 Posts
Can't these flywheels be machined and re-used? Anyone know?
I was told by my service manager to put the car into auto whenever I'm in stop and go type driving. He said this prevents the computer from hunting back and forth between gears and increasing clutch wear. I asked him twice about this because it seemed to go against the general feeling on this board, and he was quite confident. Misinformation?
wellllll.....if you burn the clutch out faster..he gets a % of the $4800 replacement....(joking)
Perhaps, but I haven't met a dealership that would do it!
Lots of people, including myself, have driven their cars with clutch utilization above 100%. It is not a completely accurate measurement. Personally, I would drive the car until either the clutch started to slip or I noticed other signs of excessive wear.
Ok so a few things to clear up I just got my clutch changed on my 03 spyder and yes the flywheel can be resurfaced with a special tool and in terms of the clutch I got one installed with the clutch sensor for under 3000. I know some of you are anal to get everything done at the dealer but unless your car is under warranty still you might as well throw away the money in the trash. If you are in So cal pm me I will give you details on where to take the car.
It's quite the opposite, the computer will "hunt back and forth between gears" when in Auto mode, since in Manual YOU are the one shifting, not the computer...
Completely agreed. My mechanic has been pushing me for almost a year to change clutch but the car drives fine.
Gcalo has a good post on clutch refits clutchmasters and one other company will resurface the FW AND refit the clutch with kevlar friction material and heavier springs but you need to send them your old clutch...most dealers will not put one in from what I have heard...I am on the hunt for a clutch core so I can have one refitted and ready for the swap then just take it to the dealer for clutch calibration
I was told by a dealer that the clutch wear indicator comes from the factory at 80% as a fudge factor.
I'm curious - i haven't run into this (yet), but i thought that somewhere on these boards I read that the CC system would not let you drive until the clutch slipped - that when the computer thought the clutch was below a certain level (30%?) the car would shut down / not shift / etc. Any truth to this? My inclination is always to drive it until I see slippage, but if the system refuses to cooperate...
Resurfacing the flywheel on a F1 transmission is major no, no. The flywheel is dished so it can not be machined. Your clutch will wear on the edges which will shorten the life of your clutch.
all those looking for flywheels i got about 6 of them laying around get them while they're hot T/o bearings to
Given that I drove my car with a reading of 0% then I would say that it is not true!
The Clutch % indicator is really an inaccurate measurement. Simply a tool that was designed to help the dealership anticipate wear and sell clutches. Not that it is intentionally faulty, however it is often inaccurate. I would not make a decision to replace my clutch based on this reading. I'd go with Paradon, drive it until it slips or doesn't drive any further. If you're worried about getting stranded and you have a CC, just replace it when they tell you to and you'll pay a bit for the convienance of it.
I also would not resurface a flywheel. It can be done properly but... it's probably not going to be performed properly. The last thing you want to do is to take on the labor and not properly fix the clutch and replace all wearable components. I'm all about saving money and I try to help many owners on this board do so when it makes sense to. In this case, you really want to get the right parts and have the job performed properly. That is not to say that many quality independants can't get the job done for less money. Just be sure that they'll stand behind their work.
Driving in Auto will not help, it can only hurt. Unfortunately the Maserati dealers often do not know nearly what they should considering the price and technology of the products the are selling. The techs will likely know more than someone you will speak to on the floor, even then... they may have gathered this information on their own and not as a result of the training they have received from the factory.
Don't get me wrong, I love Maserati, the brand and there are some great dealers here in the USA. However, it's been my experience that you'll want to verify some of the information that you're told there.
-- Jeff
See less See more
Jeff: Your input greatly appreciated and helpful to the regular readers of this forum. The expertise and common sense that you and Kent have shared with us in regard to the care of our Maseratis is invaluable - thanks!
Question for Jeff or anyone else . . .
I understand that the clutch wear reading that can be extracted via SD2/3 is inaccurate. So, when this reading shows that your clutch is very worn there may actually be a lot of life left. Question is, if the reading shows that the clutch has very little wear (like 10% or less) is this measurement more accurate? IOW, can you trust the reading more to say that the clutch is good versus the clutch being bad?
Thanks.
Thanks.
The clutch wear reading is just an estimation. If the tech that put in your last clutch did not reset parameters properly this will be totally useless. I would go by how the car feels when it is driven. You can normally fell the clutch slip on inclines or heavy load situations.
Kevlar clutch
Steve if you live in NYC I would not let the the dealer replace the clutch. Whether the original or a Kevlar rebuild which everybody says is better . I Just had FD springs installed, FD brake pads and new rotors by Classic Coach in Elizabeth NJ. it took 2 days and cost 30% less than the dealer. There labor rate is $89 an hour not $140 like the dealer. The also can do warranty work because they have a Maserati dealership in Orlando. They are primarily a Ferrari shop but work on Alfa and Maserati. Incredible place doing frame of restorations of older cars and engine modifications on new Ferrari"s . Most of all they have an honest reputation do great work, they treat you with courtesy and respect. Good luck
Thanks for the info. I'm actually in the process of purchasing a CC and the dealer hooked-up an SD2 and said that the clutch was less than 10% worn. The car feels fine but I would like to have some more definitive analysis of the wear on the clutch. I'm bringing the car to another shop (not a Maser dealer) that will do a 2nd PPI. They have experience with F1 transmissions. Is there a way to inspect the clutch for wear? Do you have to take it apart to look at the PP and bearings or is there some visual inspection possible when the car is up on the rack?
Thanks again.
1 - 20 of 31 Posts
