The MADNESS MAXPower ECM has two versions, one with bluetooth one without bluetooth.
Please note that the Non blue tooth version comes automatically set to Sport Plus and does not give you the ability to change modes.
Unlike flash tuning the MAXPower ECM by MADNESSAutoworks is undectable once removed in case you have warranty concerns when going to your dealership.
The MAXPower ECM by MADNESSAutoworks increases your performance up to 30%!
The MADNESS MAXPower ECM with Bluetooth has the ability to change to four different modes: Eco, Sport, Sport+, and off.
- ECO Mode: Slightly higher torque in the lower speed range allowing your vehicle to achieve improved fuel economy.
- Sport Mode: The power of your vehicle is further raised giving a noticeable increase in overall performance.
- Sport Plus Mode: Power is increased to the maximum safe limit giving a big power and torque increase for use on track days or special events where the highest output from the engine is required.
- On / Off: Enable or disable the MAXPower ECM. With just one click, your vehicle is in factory mode.
The MADNESS MAXPower ECM with bluetooth also comes with the "Cold Start Timer" feature, which allows the user to set in a pre-determined delay when the engine is first started delaying the tuning module from giving increased performance until the engine has reached a safe running temperature.
For those interested in the Bluetooth Version please follow the link below:
You have the option of choosing between two different maps.
One is for Street use and the other is for Track use.
Please note that the Track Version features the optional camshaft sensor which allows for improved power delivery. This version is more difficult to install due to the location of the stock camshaft sensor.
Significantly and safely increase the power of your Maserati with the MAXPower Engine Control Module by MADNESS!
The MAXPower Module was developed through a joint collaboration between MADNESS Autoworks and our International Performance Tuning Partners. Years in testing and development and countless hours of dyno and road testing have been invested into this product prior to its release to the public.
The MADNESS MAXPower Engine Control Module is truly the next level in Performance Tuning for the Maserati Ghibli. This Engine Control Module is designed to be easy to install and provides instantaneous performance gains. Unlike direct ECU flashing this module is undetectable once removed.
More information and pricing can be found on our website
We guarantee that our MAXPower ECM will outperform all other ECMs on the market in power delivery, drivability, features, and reliability or your money back! Order it, install it and use it for up to 30 days. If you are not 100% satisfied return it for a refund. It is that simple! Just call us first if you are not fully satisfied with the unit so we can assist you in the return process directions.
Do you want more power out of your Maserati? That is where the MAXPower ECM by MADNESS comes into play!
The MAXPower is what is commonly referred to as a piggy-back performance module. Meaning that it does not write to or replace the factory ECU. Instead, it sits before the ECU, from a wiring standpoint, and adjusts parameters that are heading to the ECU to generate more boost and more power!
This increase is substantial and very noticeable. For example, on a Ghibli, a MAXPower can increase the power output by 20%! A Quattroporte can see gains up to 30%!
There is no easier way to unleash more power from your Maserati than with a MADNESS MAXPower!
Designed and tuned specifically for your Maserati by us in the USA!
There is no cutting, splicing, drilling, or other destructive modifications needed to install a MAXPower. Simply plug in the three end of the wire harness, mount the MAXPower, and let it adapt!
Best of all, each MAXPower comes with a 30-Day Money Back Guarantee!
Improve the performance of your Maserati by up to 20% with the MADNESS MAXPower ECM!
This piggyback system ties into the factory wire harness, pulling data from various sensors, in order to increase boost and performance substantially!
The best thing about the MAXPower is that it does not write any data to the ECU so it does not trigger a flash counter. which can be used to void a warranty.
Because it is a piggyback it is easily removed in the event of service, sale, or lease return!
I was intrigued by the offering that Madness Autoworks offered. I spoke with Ray via email, and discovered they offered a 10% military discount. I decided to order the Max Power Module, Go Pedal, BMC air filters, and the front license mount.
The module took over a month to arrive. These are built to order and they use a supplier in Germany (this process is not built for speed). The pedal, air filters, and plate arrived fairly quickly. Happy with all three.
When the module finally arrived, the installation was relatively easy. The video on the site does a great job (the instructions included are mediocre, at best). Connecting to the bluetooth on the module is a different story. If you do buy (which I STRONGLY advise against), you must forget the MTC+ connection (or any other bluetooth) or the module will not connect.
After driving 100 miles of mixed driving I was assured the module would be great and live up to all the adverts on the site. Here is what happened......
at approx 1850 rpm through the low gears, the car lags and surges. Not minimally......but drastically. Immediately the CEL comes on. (RICH at idle, TURBO Underboost). When the car is under load (going uphill) and the accelerator is depressed, SAME symptoms. Eventually, the car even received misfire errors. According to a rep the CEL are normal, which is problematic in Texas, where annual vehicle inspections are required and a CEL is an auto fail. This should be stated on the website.
Removed the device installed the plug (which is purported to return car to original). This is not the case. Still operated the same. Sent the module back to Madness in Spicewood, TX where a representative stated it may have been loaded with the European map. Device was returned two weeks later with no packing slip and no details on as found/as left. Sent multiple emails, with no response. Finally made a post on SM (IG) and someone called and left a message stating they would follow up via email the next day with some options. Surprise, surprise.......no email ever came.
My opinion.....a bad product or faulty product can be overcome by service and support. I wanted this to work, and tried. But when correspondence is ignored, and support is poor......FIND SOMEWHERE ELSE TO SPEND YOUR MONEY. This thing will make a nice boat anchor or wheel stop.
HAPPY to provide pictures/data/questions, since MADNESS AUTOWORKS isn't going to to that for you after they get your money.
I have completely removed the Max Power module, and the car is operating as it should.
Looking for an alternative to the dealer for your regular scheduled maintenance?
Look no further as we at MADNESS Autoworks regularly perform maintenance on vehicles at our facility. You will find that our labor rates are very competitive and our service very personable.
Whether...
Your Maserati was designed to be the best grand tourer on the road. Everything from the way it looks to how it handles was designed for that one purpose. Now you can make it even better by smoothing and speeding up the transmission!
With one of our MADNESS Autoflashes you can speed up the...
Hello Everyone!
We are excited to introduce our newest release for Maserati.
Announcing the next generation of throttle pedal tuning/ managing, the new MADNESS GOPedal Plus!
Please check out the video below for more information about this revolutionary new product and as always please do not...
Have you been looking to upgrade the exterior of your Maserati Ghibli?
If so than you have come to the right place!
The demand for Carbon Fiber for Maserati's is so large so we are constantly adding new Carbon Fiber Products to be available for purchase!
We are now offering these Carbon Fiber...
