The wheel is perfect minus the insane amount of brake dust.RickBullotta said:Ouch. Luckily the wheel looks OK. Is it?
When u say underinflated how many lbs was it under? My tires are usually around 34lbs. How far lower was urs? What do u think caused the tire to be underinflated?NAPerformance said:Here is the reason why my tire popped it's because I usually check my pressure every 2-3 weeks and hadn't checked it before I went back to Oklahoma. My tires were seriously underinflated.
It was almost 1/2. The ranging went from 15psi-18psi.Lung7707 said:When u say underinflated how many lbs was it under? My tires are usually around 34lbs. How far lower was urs? What do u think caused the tire to be underinflated?NAPerformance said:Here is the reason why my tire popped it's because I usually check my pressure every 2-3 weeks and hadn't checked it before I went back to Oklahoma. My tires were seriously underinflated.
