1 - 7 of 7 Posts
Hi Maserati Braintrust,
Question: I have a humming (like a low drone) not super loud - but noticeable.
Only when I let off the gas in the 40-30 mph range - Otherwise, everything sounds beautiful 41mph+ and 29 and below,
I first thought of wheel bearings. But after viewing some examples in the QP/GT, it doesn't sound like that whoob-whoob-whoob sound, so I don't think it's that.
Could be It more like a low-frequency drone, and the fact that it goes away at any speed outside that small range is odd to me.
I'm thinking tires, a cheap easy solution to get them rotated I guess, I'll try that and report back here.
Any other thoughts my friends?
Thanks in advance.
Dude, you know I hate noises...;) Generally, when you have a noise on accel and decel and it changes it is the rear diff...Usually something with the pinion gear...The load changes the mesh between the ring gear and the pinion...make sense.? J
Reactions: paulchua
Doesn't make sense, but I'll take your word for it! haha. That said, appreciate your thoughts as always.
Cheers
2005 Coupe CC
Did you take a look at the engine mounts? In my experience, that noise starts as only perceptible in deceleration. I'm not an engine mount expert though.
Reactions: paulchua
1 - 7 of 7 Posts
