That's easy, you don't. You remove the battery, charge it and put it back in. Jumping it is not recommended because you could fry the computers if it surges.
Sent from my SM-G991U using Tapatalk
Reactions: 07 QP ZF
Definitely a preferred method but if you're using a battery pack, you should be fine. Just connect to the terminal blocks already there.
Reactions: Sock Tucker
