1 - 3 of 3 Posts
I don't want to seem stupid, and have 3 other cars with NAV systems but I can't get the Maserati nav system to start navigating. I select destination from address book or input address manually but can't get it to start navigating. What am I doing wrong or not doing. Any info is appreciated, forget the manual!
To start navigating to a destination enter an address (or select from last destinations) and then select "Destination" and "Enter".
You should be asked if you want to calculate a route - say yes.
Eventually :roll: the route calculation will complete.
Oh and all of this with the car stationary of course (it will not work otherwise).
If you go through "Other Menus" the third menu has "Enable Route Calculation" which you should ensure is set to "Yes".
Good luck!
1 - 3 of 3 Posts
