1 - 1 of 1 Posts
Hey all, I purchased a 84 bi turbo, everything seems original but someone has been in here before, I am very unfamiliar with these cars… so I am having a problem with the fuel system I think anyway, the car will start if I have some fuel in the carb (I put in) but I replaced the pump should be making about 4-5 psi… I replaced all the fuel lines, the fuel pressure regulator has fuel going into it but it’s a little trickle, then where fuel comes out I pulled that line and it is dripping out (with the pump on). I pull the vacuum line and suck on it and it has a good flow. How does this system work? Am I doing something wrong? I’ll attach a picture of the engine bay
137614
1 - 1 of 1 Posts
