Ok guys,
So I took 6 of my 8 plugs out and swapped them with the densos...
Big problem though, plugs 7 and 8 ( 2 closest to the driver on the drivers side) have the top 5mm hex screw heads (where the wrench goes) stripped...AND one bolt on the "maserati" wire cover is snapped off...
This happened either from before I got the car (not likely) or from the dealership I got my service done at (they did a bit of crappy worksmanship, which makes that senario likely).. Plus, thwy had checked my plugs, and they would have mentioned it to me if they HAD been stripped.
Before I go to the service advisor and argue with him, any tips on me just unscrewing them myself? The other bolts were all torqued INSANELY tight...
Any tips?
Any tips?
