most info on 1985 maserati biturbo 2.5l..
what do you want to know - i use to own one (actualy- i have had three biturbo's)Vazzano777 said:most info on 1985 maserati biturbo 2.5l..
I'll answer this backwards. I found Maserinet.com to be very helpful back in the days when I had mine. There are a few other Maserati sources, but were not very helpful with Biturbos back then, probably less helpful now.Vazzano777 said:i wanna know how much hp my car has
how much does it weigh
how much is it worth its in mint cond.
is there a website where i can get aftermarket parts besides maseratinet.com
helppp
in '85 there was an air-to-air intercooler available, need brackets to lower radiator, the temp senders on the thermostat housing will have to be bent to 90 degrees to clear the intercooler intake, the rest is bolt on.Vazzano777 said:what else could i do to the engine to upgrade it? as in turbos..... intercooler and all that good stuff... any recomendations?
this is beginning to sound like you want to build a "street tuner" Maserati....Vazzano777 said:would u recomend upgradeing the turbos? and putting an intercooler?
