1 - 20 of 38 Posts
Hello Friends,
I'm undergoing a NaviPlus install for a 2012 QP. I tried searching here and youtube and only found instructions on how to remove the center panel for the 2004-2008 (nothing for 2009-2013)
I tried by best to follow the old instructions and did the following first.
1) Used a soft plastic removal tool to remove the shifter indicator (instructions here)
2) Unplugged the two connectors (shown in instructions above)
3) Unscrewed the bolt under the shift indicator tool (be careful not to drop the screw when pulling out)
4) Took out ashtray (pops right out) - removed screw out underneath it.
5) Took out rubber padding on cup holders, unscrew two bolts using an Allen wrench under the two cup holders #3, #4
After all this, the trim is still stuck.
I noticed 3 holes in A, B, C, not sure if I have to unscrew those next?
127414
Any help is appreciated!
Cheers
There are two clips at the base on each side. Carefully pry them out.
127417
127418
Discussion Starter #4 (Edited)
View attachment 127417 View attachment 127417 View attachment 127418
Thanks again for your time @Cynabar , looking at my console, I just need to remove the top part, do you know how this is done?
I removed the 4 screws (2 under cup holder, 1 under shift indicator light, and 1 under cig lighter) - the top panel is still super tight, not sure what step I'm missing. Sounds like based on this video, it should come right out, not sure if it's just sticky and I need to be more forceful. I did notice however the video was for the pre-refresh Maserati QP 2004-2008, notably, he didn't mention any plug under the shift unit
Also looks like if the 09-13 QPs are the same as the 04-08 - I should be set, can anyone confirm?
Any ideas or help is greatly appreciated!
127419
The top part is secured by screws from underneath. You need to remove the whole unit by sliding it up over the shift lever (after pulling the shift knob off).
Discussion Starter #6
Thanks @Cynabar for your time, I really appreciate it. Does the gear shift twist off or is it just a straight pop off from top?
Cheers
Discussion Starter #7
I ordered a bunch of putty knives, I hear that the leather gets stuck together, I"m thinking that might be an issue to. Once I get everything done, I'll make sure to do a stop by step guide for the community.
CHeers
Discussion Starter #8
Just wanted to give the community an update. So the 4 (see #1,#2, #3,#4 in photo in first post of this thread) screws are the only thing connecting that top unit to the body. What you need to do is buy a (important: Rounded Corner-so you don't harm leather) scrapers/putty knives. You slide them in the cracks. What happens over time is the leather sort of 'melds' into each other so it gives the feeling that there is more bolts/nuts attaching the unit to the car. After you slide the putty knives in all the joints, it separates them.
Key tips
1) TAKE YOUR TIME. It's not a job meant to be rushed. It's easy but you should be gentle to prevents scratches
2) BUY ROUNDED SCRAPERS corners and don't be too forceful (You will ruin the leather if you are) - just be gentle and to repeated strokes within the gaps
3) Shift Knob pops right off (no need to twist/turn) just a gentle tug
I'm in the process of installing the Naviplus system and in deep in the process. I will be providing a primer. IN the meantime if you have any questions, don't hesitate to ask, happy to help the community.
Best wishes.
Discussion Starter #9
P.S. this is a good time to consider sending to StickyRX for button refinishing if required.
Discussion Starter #10 (Edited)
Just wanted to give an update, installed the NaviPlus and got everything running.
It was not easy and it takes A LOT OF TIME. It involves tons of wires, connections, and awkward positions. I'll try to write up a primer when I get a chance, but feel free to message me if you have a question.
Discussion Starter #12
How to remove center console dashbard panel 2009-2013 QP
Step 1 - Remove the gear shift indicator module (here is a video)
Step 2 - unscrew 4 bolts from center tunnel panel (here is a video - Video for some reason only shows 3 of the 4 bolts, they skip the bolt under the shift indicator, This video also says you need to unbend the wires, you don't need to do that, see tep 4 below))
Bolt Locations
a) Under Shift Indicator
b) Under Cigarette Ash tray
c) Under Left Cup holder
d) Under Right Cup Holder
Step 3 - Use flat scrapers with rounded corners to pry the center tunnel panel away the bottom tunnel
Step 4 - Remove the gear shift by popping it out straight up
Step 5 - Use hooked wires to pry the top vents out. Basically insert them and turn them so the hooks catch onteh center module, and pop it righto out.
Step 6 - There are 2 screws at the bottom and 2 screws at the top - unscrew these, and you'll be able to access the whole center panel. (Video from #2 shows the locations)
Hope this helps.
Discussion Starter #13
The rest of the Naviplus install just has you plugging in about 10 wires into various modules, locations, and areas. It's very tedious and time consuming. I would recommend you devote at least a full 8 hours on the job.
Discussion Starter #14
Here are the schematics to install.
Where plugs should go
The Aux Cable (Q) goes into the glove compartment (accessible through a hole in the back of the center console
Red Power cable "G" goes to camera unit (I crimped them together)
Out of center shift console is USB port to phone, extra switch, and microphone
127695
All Plugs Labeled
127696
Discussion Starter #15
Install continuation.
Pro Tip (LABEL ALL SCREWS and STORE IN SEPARATE LABELED BOXES, you will have a myriad of screws and washers and they all look the same, Save time and be tidy with the screws - you'll thank yourself when putting back together)
After you take out the center console:
1) Make sure you label with a tape where each wire goes, this will save you a lot of time when you put everything back
2) Unplug all the wires
a) One wire goes for the Hazard light
b) One wire goes into the climate control system
c) Radio has 1 huge harness plug, 3 wire plugs at the bottom, 1 video plug, and one interface plug
d) Nav screen has 2 plugs (1st goes into the main wire harness, 2nd goes to radio unit)
3) One plug to left 4 button array, one plug to right 4 button array
4) One plug to clock
Once you unplug everything you can take the whole middle panel out.
There are 8 screws that attach a frame on the back of the panel, unscrew these and take it off. The radio has 2 screws and 4 braces that attach it to the middle panel. Unscrew the 2 radio bolts and use a screw driver to carefully push the 4 braces it, this will allow you to slide the radio out of the chassis.
Once you have everything out, look at the above diagram and you'll be able to generally figure out what connections go where. One good thing is most connections are uni-size, as in - they will only fit one place.
Kudos to NaviPlus folks in Australia. They were ALWAYS quick to respond with detailed responses and friendly emails. They were always helpful and professional.
TIP#2
DO NOT PUT EVERYTHING BACK until you know everything is working as it should, you should have stuff connected and test everything before you bolt everything back together.
I'll talk about the Rear Camera next...
Discussion Starter #16
Okay the rear camera
Here's the best news about the rear-camera. The wires you need to route, you won't need any special or complicated tools, prying, or pulling out panels, trim pieces, etc. The way the QP5.5 is built, you can easily route a wire from the center console to the trunk. Seamlessly, as if the cable was meant to have always gone back there.
1) Behind the center console, there is a small hole that allows wires to come out that feeds into the driver footwell (top right corner). That wire easily slides (use soft putty tools) into the gap between the foot quarter panel and the center tunnel panel. You route the cable in that gap, and it is hidden.
2) Have the wire come out in the middle of the front driver seat, under the seat, under the carpet and into the gap (rear passenger seat). When I did this, due to the huge stock carpets, the wire is never exposed, it's always nicely tucked under the carpet
3) Jam the wire into the rear right passenger seat gaps (IMPORTANT, and under the seat belt) into the child seat latch area. There is a panel that pops righto ut where you are supposed to install child seats; the wire goes into that area.
HARDEST PART
4) There is a small hole in the trunk area (under the rear liner - you have to remove this - 3 plastic fasters and two screws to remove) - use a snake tool to fish the cable from one side of the child latch seat hole and the hole under the liner. This is best done with two people, and is by far the most aggravating part of the job)
5) Remove the plastic fasteners from the rear trunk lid, (about 12 of them) and unscrew the two screws attaching the plastic handle from the center. Take the emergency exit cable out (no screws) and take the cover off.
6) Fish the cable into the rubber connector from the undertray to the interior area of the rear trunk. I used zip ties to make it tidy as you route the cable to the rear of the trunk lid.
7) Unscrew the rear license plate panel (6 screws) to allow the cable to access the top lip of the license plate panel easily.
8) Use whatever method you prefer to fasten the camera to the license plate panel.
9) Do everything in reverse.
10) Finally, everything in the NaviPlus kit is largely 'plug n play' except the power cable to the rear camera. There is a wire from the harness that needs to be crimped to the power cable of the rear camera. Also, the rubber portion is very tiny; the camera end was too big to push through that rubber cover. So I cut the cord (so it could squeeze in the rubber cover)and resoldered them. This step is optional but does provide a cleaner stock look and feel.
Hope this helps the next soul that attempts this.
Cheers
Discussion Starter #17
One thing I forgot to mention, the NaviPlus screen has a touchscreen overlay that goes over the stock GPS screen. You'll need to remove the naviscreen from the panel so you can install the overlay. There are washers included that make sure the overlay doesn't touch the panel (for errant touches) - there is a ribbon that comes out from that overlay that plugs into a slot in the NaviPlus kit. The overlay screen has one side that is adheasive, and one side not, so easy to know what side goes where.
Final note. The NaviPlus people were great. Always quick and helpful responses. They did all their part. The Kit however is not an 'easy install' in my opinion. It's not rocket science either, but it's not a cake walk (at least to me it wasn't)
Be sure you have a lot of time and patience. Again, I would say I spent a full 8 hours start to finish.
Good Luck!
Just got around to reading this. It's truly an "oh wow" post.
Question: Does this system preserve all the various car functions that the stock system have? You know... those settings menus, etc.?
I prefer unmodified original cars. But if this has a OEM original look to it, I might consider.
Hans.
Discussion Starter #19
Hans.
It does, a button switches instantly from the Android Auto to Stock, that's why I choose this route. Be sure to read the whole thread, install is very time consuming, and does take some elbow grease.
Great info. Thank you for your time.
Unfortunately Naviplus is compatible only to facelift models with the updated NIT screen.😭
1 - 20 of 38 Posts
