1 - 2 of 2 Posts
Changing A/R (height) ONLY will change the OD of the tires.
Changing the OD will affect gearing, indicated speed, and possibly cause clearance issues (rubbing).
You can use an online tire size calculator to see how much bigger the OD gets (approximately, will vary a little with each manufacturer).
1 - 2 of 2 Posts
