1 - 2 of 2 Posts
After washing my car the other day i opened the window and then tried to close the window. It would not close. I would need need to shut the engine down and then turn it back on and then close it. But it would only close a bit each time i touch the close button. I would need to touch the button 4 or 5 times to close it all the way. If I tried to close it in one time it will not do it.
What is wrong? something shorted?
I am guessing by your symptom that you are refering to a QP.
If so, the finger trap sensor is activated. It is inside the upper (above the glass, mounted on the door) section of the window seal. Alot of times you can simply bang on the rubber with your hand across the span over the glass and get the sensor to unstick. If not then it is covered under warranty.
Hope this helps!
1 - 2 of 2 Posts
