1 - 2 of 2 Posts
As I recall, you have to pull the washer stalk out from the hole in the bumper-no easy task, and you'll probably require some gloves or even pliers. Once you have a good grab on that, you will see two tabs with holes in them on the cover which correspond to two tabs with pins on the washer stalk. It's a matter of fitting the pins in the holes, and as the stalk recedes into the hole, the cover should fit over it perfectly. It's been over a year since I had to do this, so I think I'm in the ballpark as to what goes where.
1 - 2 of 2 Posts
