Hello
I have 2018 Grancabrio and the car has a strange fault with the roof. Every time I first get in the car and try to use the roof it get stuck about 1/3 of the way through the options and beeps 3 times and says roof operation not available on the display. I can try repressing the button and it just beeps again and displays the same message. If I turn car off and back on again then it still does not work.
The only thing that seems to work is leaving the car half an hour or so and then when I go back and try it again it will finally complete them operation.
I can then close the roof fully with no issues and reopen it again with no issues.
I’ve attached a photo to show the position it gets stuck in.
Has anyone else had this issue?
thanks
thanks
