The central CC gear indicator/ OAT indicator started flashing this morning from cold start....the data would disapear/reapear on a 1.5 second cycle. Green back light still on.
Weird or what.
Stopped along the road, switched car off and back on and back to normal!
WTF?
Sounds the CC pump could be en route to the heavens...
Try a reboot sequence (battery switch off, wait for 5 mins or so before switching it on again). On reboot, key to MAR for at least 30 secs with the NIT off. Then start the engine and see what happens. If the warning light re-appears, get your wallet prepared... if not, try to get your dealer to read the error code to see what has happened, for your peace of mind.
Just my 2 cents.
if you try to reboot by disconnceting the battery will you need the maserati code from your code card? I dont have my code card so am always worried about battery going flat. Is there any way of getting the code card/number?I am in Uk.
