OK. Now feel really stupid. Just Purchased a 2016 Ghibli S and cannot re-fuel the car!!! Flapper Valve blocking the till hole will not open???
so when you try to push the fuel gun nozzle into the flapper, it won't open? if that is the case, replace the fuel filler neck. there should also be a funnel in the trunk road side kit that is meant for using with a gas can. you can try pushing that in.
