Front end alignment specs.
24147 Views 106 Replies 30 Participants Last post by  sdfsd99958
At 32k miles I am on my 3rd set of front tires for my 2014 Gran Turismo S. I have had a couple of alignments one indy shop , one dealer to factory spec, but the inner fronts still seem to wear out at about 15k miles. I'm guessing that a tad less negative camber might solve this issue without affecting handling too much.
Has any one out there found alignment specs for the front that keep the car from eating front tires? If so could you please share them with me
Thanks,
MIchael
1 - 20 of 107 Posts
Thanks,
MIchael
15k on the fronts is not terrible on these cars. But try, at the very least, a neutral setting (0.0) for the front toe...a degree or two positive is also good. (y)
I still cannot understand why this topic is not a "Sticky" thread with answers on this website.
Sticky buttons, Alignment, Variators, ect...questions come up almost weekly.
Insane that these frequent topics are not Stick Threads WITH answers....
Reactions: 2
My car has been setup by a race shop (do suspension work for le mans cars) by hand (using a wire and measuring tape). They never looked for factory specs, just setup using their knowledge about RWD cars. Inside still wears more, but it is only about 0.5-1mm worse compared to the outside. My fronts have been on car now for 15k miles and fronts still have enough life for another 15k. Rears are about done.
With this setup the rear feels more in line with the front when changing direction/cornering.
I have attached the official setup sheet
Text Paper Document Font Line
See less See more
Reactions: 4
Thanks,
MIchael
Hi Michael:
When I picked up my GT I drove it back from Chicago to Knoxville and it felt great. It had 14k miles on the original tires. I had an alignment done when I had the rear tires replaced. When I got it back it felt odd on the freeway. It didn't feel like it did before the alignment. It felt like it didn't want to stay straight on the freeway and required constant correction. I looked at the invoice from the dealer and the alignment said set to preserve tire life. I called the dealer and they said that the GT's bald the inside of the front tires because of the factory specs. So they use different alignment settings that preserve tire life over better handling. I opted to go back to the factory settings and am much happier with the handling, though I know it will eat tires up at a faster rate. I did change from Contis to Michelin's and like the Michelin's better then the factory Contis. I regularly check the front tires for wear by full crank to check wear. So far nothing noticeable yet, but once it starts it happens quickly based on experience. I put about 10k miles a year on the car, so I'm expecting that I will be replacing the fronts once a year and am okay with that since it increases my enjoyment of the car.
Regards, Marc
See less See more
Reactions: 2
Done
Reactions: 1
The FSM States:
Tyres 245/40 R19 285/40 R19
245/35 R20 285/35 R20
Pressure 2.2 bar 2.2 bar
Rims 8.5J x 19” ET 52 10.5J x 19” ET 37.5
8.5J x 20” ET 52 10.5J x 20” ET 37.5
Camber -0°30’ +/- 0°10’ -1°30’ +/- 0°10’ 1 - 2
Front
Toe-in -2.1 +/- 0.4 mm (for R19
rims)
Rear
+4.2 +/- 0.4 mm (for R19
rims)
Front
-2.2 +/- 0.4 mm (for R20
rims)
Rear:
+4.4 +/- 0.4 mm (for R20
rims)
Caster +4°00’ +/- 0.2 5
Height 165 +/- 5 mm 152 +/- 5 mm
Axle track 1586.0 mm 1590.8 mm
Wheelbase 2942 mm
Weight 1015 kg 1085 kg
Steering angle Int. 33.0°/ext.39.0°
What is the latest spec for best handling / and minimal tire wear?
See less See more
This is a great forum.
Thank you.
We aim to please. The risk is we end up with a hundred sticky threads, and people will start their own anyway.
Obviously I can lock them and prevent drift, but always happy to do the needful
Discussion Starter • #3 2 mo ago (Edited)
Here’s the before and after. A&A Tire is a big shop, 5 Hunter Alinement racks. Maseratis are rare, so the lead guy did it and let me watch (bought him a few beers) on their new rack. The Mas was in the computer so it went well. See pics. The only change from factory was to go from -0.06deg to +0.06deg toe. That was the consensus recommendation from the last major thread on the subject. Car handles much better, no more wandering.
Text Diagram Design Plan Font
See less See more
Reactions: 3
Are we going off this then? Should we use this for 20inch rims
Yes 20" wheel, it's right at the top.
Rectangle Font Parallel Handwriting Technology
See less See more
Yes 20" wheel, it's right at the top. View attachment 136216
I meant is this the alignment we should be doing for our 20 inch rims? Should I go off these specs, was looking for some positive reinforcement.
Are you experiencing any issues with your current alignment? Premature tire wear or the car pulling to one side?
Well I need to change the tires on my car, I thought it was normal to do a wheel alignment when you put on new tires/balance.
True, a new alignment is customary with most when you put on a set of new shoes. Member Cynabar has noted good results from his alignment numbers so you can surely see how they will work for you. (y)
Reactions: 1
Hmm, I never subscribed to that practice .. absent any signs of uneven wear in the old tires, or the car pulling to one side, or if you hit a heck of a pot hole.. not sure why you would do an alignment . Balance , sure, but alignment may be overkill with every tire change . IMO
Reactions: 2
Me neither Dan, that's why I said most :p
I only fix it when it's broken...
Reactions: 1
Right you are, apologies.. I read past the most too quickly ..☺. Must be the same “most” crowd who replace perfectly good rotors with every brake pads change .. 😉
Reactions: 1
No apology needed friend...and I'm sure it's that 'rotor crowd' :ROFLMAO:
Reactions: 1
1 - 20 of 107 Posts
