1 - 1 of 1 Posts
Had to repair one of the hydraulic lines that had sprung a leak on my 2002 Spyder. When assembled the line was crushed by a nylon tie that Luigi made too tight. With the line flattened and with the flexing caused by the cylinder having to rotate around 90 degrees (cylinder for rear arch) the line eventually cracked.
Rather than buying a new line I used the following connector https://cabriolethydraulics.com/our-products/hydraulic-hose-repair-couplers/. Easy to install if you can reach the leak and seems to work just fine.
1 - 1 of 1 Posts
