1 - 9 of 9 Posts
Welcome and thank you in advance.:):)
Serkan,
Welcome, I took some time to peruse your web site and blogs, really great stuff! You and Wil are very talented and I thorougly enjoyed reading about your projects and seeing many mechanical pieces of art. Thanks for offering to share your experitse.
Hello Serkan:
I have SD3, but do not know the correct procedure to do the clutch adaptation and set up the parameters.
Could you provide this info.
Thank you in advance.
Hello Serkan:
Hi
It is complicated if you stop by to my Ferrari Service whit your SD3 and/or call me when you have it connected I will help you no problem. I have sum Factory SW for SD3 ! I will help you whit your F1 ex..
bye
Cambiocorsa dash icon
I'm not only new to this forum, I'm also the new owner of a 2002 Cambiocorsa Spyder. I wonder if you would be kind enough to speculate on why the transmission icon on the panel turns on and off intermittently. I'm thinking it may be a sensor issue. The tranny and clutch seem to operate properly. While there certainly are all kinds of serious causes of such a display, perhaps there are also some trivial ones. Thanks.
1 - 9 of 9 Posts
