what a serious improvement this is on my car!
I drive with the ECM on the most aggressive setting and DBW on the less aggressive setting as the higher setting can be a bit too touchy in heavy traffic with sport mode turned on.
The best part about these mods is I can revert back to stock for warranty issues, best of both worlds! I tested this out last week when my nearly new 2013 sport with 2,500 miles had a rattle from the exhaust on cold start. The car was at the dealer for two weeks as they looked over everything with a fine tooth comb and replaced both mufflers and nothing was said about my mods (which were removed and bypass plugs installed)
The DBW is so important in city driving as the throttle was mash potatoes before, with the less aggressive setting it drives perfect! Not too aggressive and worlds better than stock. If I did not live in a city with a lot of traffic I would always drive around with the most aggressive setting turned on the DBW.
The ECM on most aggressive setting gives the car the extra oomph it needs on the highway. I never tried the less aggressive setting for ECM and probably never will.
A car that looks this mean deserves to drive way more sporty than the factory makes 'em. FD did an excellent job with these mods. If you are looking to make your GT drive more like the exotic car it looks like then this is for you :cheers:
