Just got the car back from Eurosport who installed the BBK. Check it out. Car stops infinitely better.
D
Performance Specialist
Thanks for the pictures and I'm glad to hear that the new kit is working well!
-- Jeff
Maserati Big Brake Kit Upgrade
This is our stage 2 brake kit if you will. http://www.formuladynamics.com/products/4200_fd_bbk/4200_fd_bbk.php
* Designed Specifically to fit the Maserati 4200 Series Coupe, Spyder and GranSport Models
* Saves 12lbs of unsprung, rotating weight!
* Significantly Improves Braking Power and reduces stopping distances!
* Fits Factory 18" and 19" Wheels
* Includes: Oversized, Floating, 355mm, 2-pc Cross Drilled Rotors with Lightweight Aluminum Hats
* Includes: Stainless Steel Braided Brake Lines
* Includes: Carbon / Kevlar Performance Street Brake Pads
* Includes: (3) Bottles of MOTUL RBF 600 Racing Brake Fluid
* Includes: All Necessary Hardware to perform the conversion
* Performs substantially better than OEM Parts and improves vehicle safety
* Made in the USA
-- Jeff
