So,
I think my Clutch is shot.
Car: 2006 Gransport, Milage 60k (96560 KM)
Maintenance History: unknown
Issue: Transmission skips 1st but will go into second, will not go into reverse. (suspected safe mode/ limp mode)? Please note: Its not throwing any codes whatsoever .
I have driven the car with almost no issues until now for about 7000km since i purchased it.. Until about a month ago when i noticed the clutch engagement was becoming slower than usual. On hill starts the clutch would struggle to fully engage quickly, the engine rpm would rise then drop gradually until I felt engagement about 2 - 3 seconds later.
On my last drive before shit hit the fan It reluctantly clunked into first at a stop then after only went into second gear. During shifts afterwards my rpms would drop then rise for a second before dropping and engaging. I barely got it home.
Considering the Mileage I am almost certain it is a worn clutch causing the system to have a fit.
Before I start taking the car apart Does this sound reasonable to assume?
Thanks,
Dan
I would at least go get a diagnostic scan before assuming it’s a clutch. I think most dealers and independents will do it for about an hours labor .
Not limp mode. Limp mode limits you (or attempts to) to 1, 2, and R.
It could be the clutch slipping.
I'd recommend connecting it to a SD. If clutch checks out, I'd start with checking your gear change grid and try to recenter the actuator tooth.
Agree with others. Need to get a SDx or equivalent connected up.
Where in Canada are you located? If you're in the GTA, feel free to private message me and I can probably help you take a look.
